My comes on but wont burn
Hello, im having issue with mysweety 3018 DIY CNC/Laser. Im new to light burn and could really use help. My laser will come on but wont burn the wood. My first question is how compatible is the 3018 with lightburn and next, am i missing something in settings?
What needs to be compatible is the controller and the 3018’s work fine, I have three of them with different controllers…
It’s probably not setup in the configuration.
Did you enable the laser in the ‘machine settings’?
Did you set it up as specified by the Lightburn grbl setup procedure?
