60 watt co2, 100mm/s, 13% power, 300 dpi, stucki dither in LB.
It’s a great start!
And it is the bees day today !!
I see it coming, I will also try to burn tiles …
7.8 watts… what’s the lowest your laser will fire effectively at?
Try lower and slower. I think you will be presently surprised at the difference.
Your images are beautiful nice Job!
Sasquatch
Way better than I have been able to get with my 65 watt.
10% is the lowest it will fire at. 13% at 100mm/s seems to be the best combination for ablating the paint completely without causing it to start to turn brown.
I usually use the standard 2 inch lens. I also have a 1.5 inch meniscus lens, but I have not been able to tell much difference when I use it.
You have LB controlling your Z axis?
No, I set the focus and that is the Z for the entire job. Not sure I know how to make LB control the Z?
Is your Z motorized? What controller do you have?
yes the Z is motorized, and I have auto focus. The Boss uses the Ruida controller
Go to Edit>Device Settings and tick all three switches green under Z axis control. Then go to the Move window and see if you can move your Z with Lightburn.
Yes, I know that LB can move my Z axis
Try running that file I posted. If you have a magnifier I think you’ll def see some difference between the 2" and the 1.5" lens. I’d also bet that your focus, even with autofocus, is off a bit.
Oh, I see, your test file is moving the focus up and down a bit to show where the best focus point actually is. I thought you were saying that you were having LB change the focus (z height) while scanning the image.
Thanks for explaining.
@Allen If you are going to be looking at small dots do yourself a favor and invest in this
It’s a game changer. It has a glass scale to measure distance between dots.
Cheers
Exactly. The file itself is changing the Z height for each column by .1mm. Helps zero in on perfect focus.
Way ahead of you, when you first showed it I ordered one. It is really nice for the price
Curious what you find in your testing.
