I run Lightburn on Chromebooks exclusively. Intel-based Chromebooks will run Lightburn if the Linux development environment is enabled.This allows the Linux Lightburn .run to be downloaded and run… though it will require a little bit of file manipulation. As @sohier said… some comfort with Linux and the command line will be required. Here’s some instructions to get started…
