My Image does NOT burn where the Framing happens
Hello, I am having issues of my images NOT burning where it shows the faming at.
I will run the framing, and then when I hit start, the laser moves slightly downwind to the right, then it will burn.
Also, are there any tips/tricks that anyone knows of to get the image to burn where I put the laser cone. I have already turned off the “Enable Pointer Offset”. I do not want to waste wood that I have and I want to be able to use it again, for other things, especially if there is still space on the wood to use. I want to know how to Frame correctly weather it is a New wood piece or something I have used for another project and there is room left.
If you’ve disabled the “Enable pointer offset”, are you framing using the crosshair or the blue diode laser?
Normally you’d use the crosshair if using the pointer offset. Without the pointer offset the assumption is that you’d be using the blue diode laser at lower power to frame.
If neither of these situations apply can you provide the following:
  1. screenshot of Edit->Device Settings
  2. full screenshot of LightBurn with the design loaded and ready to frame and burn
  3. go to File->Save gcode, save to a file with .txt extension, and upload file here
Hello,
I had turn the CrossHairs off, thinking that where I put my laser is where it would start. Unfortunately due to me being still very new to this, I do not know show to turn on the blue diode
I have also attached the 3 screen shots that you requested
DST_Double Letter Cutout.txt (5.9 KB)
In Move window, adjust the Power level of the Fire button to below 1%. Have you goggles on then push the Fire button. Increase power incrementally until the light is visible. Ideally you’d have this at the lowest level where you’re able to see the laser.
In reviewing the gcode there could be an issue with the code but can’t say as yet.
Can you first try framing with the blue diode and confirm if framing location matches burning location?
Ok, Yes I was able to turn on the Blue Diode, thank You
Now yes, the image is burning where the blue diode is and my Fire power is at .5%
I still have this question: See below. Thank You
Also, are there any tips/tricks that anyone knows of to get the image to burn where I put the laser cone. I have already turned off the “Enable Pointer Offset”. I do not want to waste wood that I have and I want to be able to use it again, for other things, especially if there is still space on the wood to use. I want to know how to Frame correctly whether it is a New wood piece or something I have used for another project and there is room left.
I will give this a try…
Absolute Coords.
Home machine if capable.
Move to front-left, power up, and Set Origin if no homing switches.
Never move by hand after power on.
  • Jog laser to CENTER of what you want to burn.
  • In Laser window, click “+Show Last Position” button.
  • In Workspace window, you should see a small red cross.
  • In Workspace (drawing) window, highlight (CTRL-A) your work.
  • Mouse to the center of your work, click and drag that center onto the top of the red cross.
  • You now have the physical locations of the laser and work aligned.
  • Frame should be pretty close to correct. If not, re-scale the drawing or move your part to be burned slightly, but do not move the laser or the drawing center.
I found this method also allows to quickly relocate to unburned / uncut areas of the workpiece.
Let us know if this is not what you are asking for.
Good Morning!
My apologizes for the late response. I am trying all of these this now to see if this works. I will soon let you know
This worked Perfect! Thank You!!!
Great! We can call it the “Mikey Method”?
Be sure to check the Solution box. :smiley:
It is the BEST!!! Made it all so much easier for me…especially due to I am new to this particular machine.
Glad you liked it, and glad a newbie helped a newbie!
