My Laser does not move, as i want to: right left not anymore, laseren Image not correct
i cant use my laser as i want to. does not move right left, and by the engraving it only moves vertically. Please Help, hier the messages : <Idle|MPos:-527.500,-537.500,-10.000|FS:0,0|WCO:0.000,0.000,0.000|APP:33|USB:0>
ok
Starting stream
[MSG:Program End]
Stream completed in 0:00
$0=1
$1=25
$2=0
$3=0
$4=0
$5=1
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=1
$22=1
$23=3
$24=300.000
$25=3000.000
$26=250.000
$27=3.000
$30=1000.000
$31=50.000
$32=1
$100=100.000
$101=100.000
$102=1600.000
$103=100.000
$104=100.000
$105=100.000
$110=50000.000
$111=20000.000
$112=1000.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=4000.000
$121=1000.000
$122=500.000
$123=200.000
$124=200.000
$125=200.000
$130=365.000
$131=305.000
$132=40.000
$133=300.000
$134=300.000
$135=300.000
ok
G10 L2 P1 X0 Y0
ok
SI
error:2
Numeric value format is not valid or missing an expected value.
$I
[VER:C10-0085-V1060.Dec 21 2023:]
[OPT:HLSW,512,2048]
Target buffer size found
[MSG:Mode=STA:SSID=:Status=Not connected:IP=0.0.0.0:MAC=84-FC-E6-4D-57-0C]
[MSG:Mode=AP:SSDI=Engraver_3159:IP=192.168.4.1:StationNum=0:MAC=86-FC-E6-4D-57-0C]
ok
$0=1
$1=25
$2=0
$3=0
$4=0
$5=1
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=1
$22=1
$23=3
$24=300.000
$25=3000.000
$26=250.000
$27=3.000
$30=1000.000
$31=50.000
$32=1
$100=100.000
$101=100.000
$102=1600.000
$103=100.000
$104=100.000
$105=100.000
$110=50000.000
$111=20000.000
$112=1000.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=4000.000
$121=1000.000
$122=500.000
$123=200.000
$124=200.000
$125=200.000
$130=365.000
$131=305.000
$132=40.000
$133=300.000
$134=300.000
$135=300.000
ok
[G54:0.000,0.000,0.000]
[G55:0.000,0.000,0.000]
[G56:0.000,0.000,0.000]
[G57:0.000,0.000,0.000]
[G58:0.000,0.000,0.000]
[G59:0.000,0.000,0.000]
[G28:0.000,0.000,0.000]
[G30:0.000,0.000,0.000]
[G92:0.000,0.000,0.000]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
ok
<Idle|MPos:-527.500,-527.500,-10.000|FS:0,0|WCO:0.000,0.000,0.000|APP:33|USB:0>
ok
G10 L2 P1 X0 Yo
error:2
G10 L2 P1 X0 Y0
ok
Thanks for the help
G10 L20 is similar to G10 L2, except that instead of setting the offset/entry to the given value, it is set to a calculated value that makes the current coordinates become the given value .
i dont think that is the problem, mabye with the configuration , thanks for the help
the laser does not move on the horizental axe
These values are very high. They may be higher than your machine is capable of achieving. Do you hear a buzzing noise from the machine when attempting X movements?
I suggest reducing these to safer values.
$110=6000
$111=3000
If this works, you could incrementally tune the machine to higher settings.
