When I had not upgraded to version 14., the laser worked normally. However, now I have a situation where when I connect the laser to the USB, the laser automatically lights up with high intensity. Please help me.
Version 1.4.03?
This is a terrible situation. Thank you for reaching out. This should be very difficult to enable and almost impossible to do accidentally.
The first step is to unplug the laser module at the laser and move the cable out of the way if needed. If the engraver complains about a flame sensor or shock / g-force / acceleration sensor we can address it if and when it emerges.
- How many wires are on the cable to the Laser module?
- Did you upgrade or change the module?
The laser intensity is controlled by the controller, connecting a USB cable to the controller shouldn’t send the commands to activate the laser. (We should confirm this by running a couple of tests on your engraver.)
We need to know more about your DIOT Laser to help.
Please help by sharing the name of the manufacturer, model number, or the welcome message when you first connect.
Did you update or change any Firmware in the controller?
Is there a memory card in the controller?
Most often the SD or TF cards clock data in from the card with the same Data pins as the USB. The USB cable shouldn’t activate a stored program but this seems like the most likely possibility for automatically starting the laser.
