My laser performs framing (with low-power ignition), but does not start engraving.
My laser does the framing (with low-power ignition, but does not start engraving, no head movement.
Sculpfun S10, Windows 10.
Thanks for your help
Mon laser effectue le cadrage (avec allumage à faible puissance, mais ne lance pas la gravure, aucun mouvement de la tête.
Merci de votre aide
Do you get any error message in the console window?
Check the power supply is connected. If you have another power supply to test the laser with…
Hello, and thank you for your attention.
  1. The console does not give me any error or anomaly message, when I ask for engraving, nothing happens…
  2. I don’t think it’s a power supply problem, because when I launch the “framing” function, the head moves according to the requested framing by switching on the laser diode at low power as set in Lightburn.
  3. Is it possible that LB won’t start engraving because I’ve just exceeded the trial period before buying the licence?
Bonjour, et merci de votre attention.
  1. La console ne me donne aucun message d’erreur ou d’anomalie, lorsque je demande la gravure, il ne se passe rien…
  2. Je ne pense pas à un problème d’alimentation, puisque lorsque je lance le “cadrage” la tête se déplace bien en suivant le cadrage demandé en allumant la diode laser à faible puissance comme paramétré dans Lightburn.
  3. Est-il possible que LB ne lance pas la gravure, du fait que je viens de dépasser la durée d’essai avant achat de la licence ?
Translated with DeepL.com (free version)
Set the power in your cut settings to 1% and run the same project again. If the laser is able to move and start your project that could still mean your power supply is weak.
If your Trial has expired you simply won’t be able to launch the program, LightBurn does not limit functionality when the trial period has expired.
Hello,
I did carry out the 1% test, tested my power supply, the tests showed no change…
But, since I entered my activation key, everything has been working perfectly without having changed any of the burning parameters, so my problem is solved…
I deduce that LB blocks the burning function beyond the trial period.
Thank you for your attention and your help.
Bonjour,
J’ai bien effectué le test à 1%, testé mon alimentation, les essais n’ont montré aucun changement…
Mais, depuis que j’ai renseigné ma clé d’activation tout fonctionne parfaitement sans avoir modifié aucun paramètre de gravure, mon problème est réglé…
J’en déduis que LB bloque la fonction gravure au-delà de la période d’essai.
Merci de votre attention et de vos aides à Tous.
If your trial or your license has expired you will simply not be able to open the program. You will be greeted with a message window and then you can press OK to close LIghtBurn.
Your deduction is not correct.
