My laser stops the work after receiving some seconds or a few minutes
Hello there,
I am completely new to laser engraving.
I got the TTS 55 Pro since some days.
Unfortunately the laser stops working after receiving this:
“Guru Meditation Error: Core 1 panic’ed (Unhandled debug exception). Debug exception reason: Stack canary watchpoint triggered (LED task)”
I tried to google, but can’t find answers to it.
I hope somebody can help me.
Thanks a lot,
Sven
Not familiar with TTS 55 Pro firmwre but try
a) $RST=* in console to make sure you are in defaults
b) Update firmware if necessary
c) Make SURE you are using GRBL controller instead of GRBL LPC or M3
d) Make sure you do not have gcode cluster enabled
This said, that error is a kernel error sort of thing so the controller software itself is crashing, seems firmware related
See if your firmware and the latest at their page match
Thanks for your answer.
Everything should work fine.
But I still receive following message from the console:
Core 1 register dump:
PC : 0x40380c83 PS : 0x00060036 A0 : 0x8037f39c A1 : 0x3fcae440
A2 : 0x3fc97b50 A3 : 0xb33fffff A4 : 0x0000cdcd A5 : 0x00060023
A6 : 0x00060023 A7 : 0x0000abab A8 : 0xb33fffff A9 : 0xffffffff
A10 : 0x3fc97b28 A11 : 0x00000001 A12 : 0x00060021 A13 : 0x3fcae620
A14 : 0x02c97b50 A15 : 0x00ffffff SAR : 0x0000000a EXCCAUSE: 0x00000001
EXCVADDR: 0x00000000 LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000
Backtrace: 0x40380c80:0x3fcae440 0x4037f399:0x3fcae480 0x4037d8c0:0x3fcae4b0 0x4037d8b6:0xa5a5a5a5 |<-CORRUPTED
ELF file SHA256: a61dcf28796700fc
Rebooting…
E (26) uart: UART driver already installed
[MSG:Using machine:MKS DLC32]
E (30) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first
E (36) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first
E (46) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first
Grbl 1.1h [‘$’ for help]
[MSG:Local access point MKS_DLC44037 started, 192.168.4.1]
[MSG:HTTP Started]
[MSG:TELNET Started 8080]
Auftrag angehalten
Stream fertiggestellt in 13:55
E (359599) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first
E (359600) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first
E (359610) gpio: gpio_isr_handler_remove(480): GPIO isr service is not installed, call gpio_install_isr_service() first
Does that help any further?
I wouldnt be able to help much more but maybe someone else can
I would advise taking that same data and contact the manufacturer i am pretty sure they might have seen it before and have a direct solution
To me is a firmware issue and as it says in the debugger is crashing the firmware kernel kinda thing. Why i wouldnt know
