My laser tube produce double line
Typical cut settings apply more power than necessary, so you will never notice a failing tube until the power level drops below the absolute minimum required for a clean cut.
Because the beam is not shaped properly, it cannot be focused properly. The beam shape varies with the distance from the laser tube, so the effect on the material varies with the position on the platform.
As long as the beam cuts through the material, however, the laser seems to be working, even though it is getting worse.
I do not know the physics of gas laser operation beyond the level of a reasonably well-read, somewhat obsolete, electrical engineer.
Edit: A brief explanation of modes.
The ā€œmodeā€ of a laser describes the stable state of the energy resonating within the tube, which depends on the perfect alignment and condition of the mirrors inside the tube (not the outside mirrors we can adjust), with tolerances measured in fractions of the light wavelength. Any combination of mechanical stress, material aging, temperature variations, gas contamination, and other things I can’t even pronounce will suffice to wreck the laser’s mode.
It’s a wonder lasers work at all … :grin:
Here is a more technical description of TEM modes from Edmund scientific.
This link, also Edmund Scientific, explains the beam quality or M2. I suspect this is what gives us problems.
Remember a lens only duplicates the source, if the beam quality is not good, then you get strange results, such as difficulties in alignment… Unfortunately, there is no simple way to measure what’s going on inside the tube.
My tube went out of TEM00 mode over a 3 day weekend and didn’t have a lot of hours on it either.
Ever put a new bulb in and it didn’t work or only lasts a few weeks? … such is life.
Now I understand everything. I do not have anything to say to you except thank you!
You were very helpful and kudos for the knowledge!
Yes when I bought the laser, he came with the damaged laser tube I could not align the mirrors properly, and than I bought the new one and now I have a problem with it.
I have a reci 100 watt tube, is it typical for reci tubes to break so often?
No they are usually very good, one of the top. They have a warranty period, could it still be covered?
Unfortunately warranty period on my tube expired.
The best for me now is to work with this one while it is working somewhat good until it fails completly.
Good luck… it’s not possible to do a correct alignment with a tube out of TEM00 mode. When mine went out, I ordered a new one and spent 5 days, aligning it more than once daily. My mode changed over time.
These are one of the best tubes you can get, I’m sorry you’ve had a less than acceptable experience with RECI.
Good luck
Thank you very much, you were very helpful!
:grin:
