My new laser LONGER B1 30 doesn't cut
I am new to this. Am I doing something wrong or have I not set it up? But my laser longer B1 30 does not cut. For example, i drew a simple cube to cut out for testing. I put speed 1000 and power 50. And what happens. He draws me a slight line and throws the error, I already wrote about G-code locked out during alarm or jog state. Please, I’m already desperate…can you help?
Note that 1000 by itself is not a speed. You need the units to express this properly.
You are set to 1000 mm/s which is absurdly fast.
2 suggestions:
  1. Change your units to mm/min for diode lasers in Edit->Settings
  2. Dramatically reduce speed. I’d suggest starting at 500 mm/min @ 5% power. Then adjust from there.
Looks like he is on mm/sec. I think his main issue is error codes per his other post.
First attempt…but not cut… speed 500 power 5%
Second attempt speed 500 power 10% laser doesnt start it is in place and throws an error…i set it up for diode mm/min
Seems to me you’re experiencing a communication error. Try swapping USB cables.
