My preview laser is the wrong size
Ezcad2 works fine pre scan to show box and then burn is fine both same size on my fibre.
But on lightburn the pre scan does not match the burn. If i create a 1" box the pre scan does not match so i cannot do this laser image to test position.
This all works on ezcad2
When i added the galvo and ezcad2 to lightburn
I followed proceedure of browsing to the ezcad2 config file but it has not pulled into lightburn the correct setup.
Can you show the image and file ?
The file that came with mine was markcfg7. I imported it when I set up the device, so if it’s working in EZCad2, then it should work with Lightburn…
Did it give you any errors or anything?
Are you talking about the frame function or the preview function?
It sounds like you need to adjust the Red Dot Scale and Offset in the ‘Device Settings’ window:
Yes sorry its the frame function thats well out but fine in ezcad2.
I will double check which config file i imported in.
It set the correct laser type and lots laser setup but it failed on the framing function in lightburn.
Thank you guys for your help and guidence.
Very much appreciated.
