eruditen
(billie boyd)
February 18, 2024, 6:00pm
1
My atezr v35 laser cuts a 100 x 100 mm box as 100mm(x) x 132mm(y)
I discovered this while trying to calibrate the atomstack a1c camera. The camera will not calibrate. It is off my 4 to 5 cm and i can’t get it to align so I stmbled on sizing issue.
I read about calibrating x y axis but I don’t understand the instructions.
gilaraujo
(Gil Araújo)
February 18, 2024, 6:37pm
2
Any chance you enabled rotary mode in lightburn?
Or changed the firmware settings?
eruditen
(billie boyd)
February 18, 2024, 6:38pm
3
rotary is not enabled .
My next thought is to unistall and start over but I can’t find how to uninstall the laser.
gilaraujo
(Gil Araújo)
4
in console type
$$ press enter
Copy/paste the full output here
Also triple check rotary
gilaraujo
(Gil Araújo)
February 18, 2024, 6:39pm
5
Go to Devices _> delete device > add it again
But this shouldnt be it
eruditen
(billie boyd)
February 18, 2024, 6:41pm
6
It has a lot of stuff. Is there a way to clear the console so it starts fresh?
gilaraujo
(Gil Araújo)
February 18, 2024, 6:42pm
7
close and restart lightburn
eruditen
(billie boyd)
8
$132=200.000
$133=300.000
$134=300.000
$135=300.000
ok
Is what is showing in just the window.
gilaraujo
(Gil Araújo)
February 18, 2024, 6:43pm
9
need to post all items, from $1 to the bottom
So a bit of scrolling up is necessary
eruditen
(billie boyd)
10
Wait. I rolled it to the $$
$0=10
$1=25
$2=0
$3=3
$4=0
$5=1
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=1
$22=1
$23=3
$24=300.000
$25=3000.000
$26=250.000
$27=1.000
$30=1000.000
$31=0.000
$32=1
$37=1
$40=2
$100=80.000
$101=80.000
$102=80.000
$103=100.000
$104=100.000
$105=100.000
$110=20000.000
$111=20000.000
$112=6000.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=1000.000
$121=1000.000
$122=1000.000
$123=200.000
$124=200.000
$125=200.000
$130=430.000
$131=850.000
$132=200.000
$133=300.000
$134=300.000
$135=300.000
ok
gilaraujo
(Gil Araújo)
February 18, 2024, 6:48pm
11
eruditen:
$100=80.000
$101=80.000
$102=80.000
your steps per mm are correct
Your size of shift is TOO big to be a belt tension issue, therefore i am certain that something is up with your rotary mode
I would
a) in console type
$RST=* press enter to reset to defaults
b) redo your profile and make sure there are no odd settings
c) rerun the job making 100% sure rotary is NOT enabled
eruditen
(billie boyd)
February 18, 2024, 7:03pm
12
gilaraujo:
$RST=*
Rotary off. Checked again. RAn $rst=* and it cut a box!!! 100x100. Thank you!
Now, maybe my camera will align!
eruditen
(billie boyd)
February 18, 2024, 9:55pm
13
well No joy in mudville. NOw the camera image isupside down so the search begins again. Thanks.
eruditen
(billie boyd)
February 18, 2024, 10:13pm
14
what does redo my profile mean?
system
(system)
Closed
March 19, 2024, 10:14pm
15
