Mystery Power Drop on Fiber Laser
Maybe someone here can shed some light on this mystery.
Here’s what happened: I accidentally fired up my fiber laser with the protective cap still on the lens. The beam burned a hole straight through the plastic, a nasty burnt smell filled the air, and I killed the laser after literally two seconds.
When I powered it back up to engrave some steel, it behaved like it was running at maybe 5–10% of its normal power. My first thought was that I’d cooked the galvo. Out of desperation, I swapped out the 100 mm lens (the one I’d been using) for a 225 mm lens. The laser instantly ran at full power again. Swapped back to the 100 mm lens—only 5–10% power. Back to the 225 mm lens—full power. Back to the 100 mm—barely any power.
I finally cleaned the 100 mm lens, even though to the naked eye it looked perfectly clear. Put it back in, still only 5% power. Swapped to 225 mm—full power. Put the 100 mm back in—and magically, it’s now running full power again.
Can anyone explain what the hell is going on here?
Looks like you damaged the lens. I’m not sure how, but I’ve seen people do this and only loose the lens cap.
Don’t have an explanation as these lenses are for 1064nM, which we can’t see.
Maybe there’s something there that only effects this ir wavelength.
And that explanation would make perfect sense to me… if it weren’t for the fact that after swapping the lens a few times, it suddenly starts working again :slight_smile:
The only way I know to break one of these is not screw it in all the way. Since you took it in and out you must have disturbed something.
It might not be visible to you… Just keep them clean.
Have fun.
