Alguien me podria dar algunos tips para mejorar la configuracion para el grabado de imagenes
Could someone give me some tips to improve the configuration for recording images
Gracias
Thanks
Thanks
In what way would you like to improve the image?
Do you want more contrast? More detail?
Personal preferences make this a difficult question to answer.
Usa el truco de la cinta de papel, también cuando es madera creo que hay un truco con rociandole agua con bicarbonato a la madera se ven mas oscuras las imágenes
Record a grayscale test on a piece of material that you are going to use, varying power and speed to find the tone you like.
An image like this, for example:
Now check your result: you may have more than one slice white, and more than one slice of the same black, but you can easily recognize a range of power where you can see difference between slices: this is your “good range”.
Repeat the test using the previous speed but “correct” Smin and Smax to match the “good range”.
I mean: assuming your laser use 0/1000 and your test show “good range” between 20% and 90% set SMin = 200 and SMax = 900.
