Kenneth, probably the simplest option would be to delete Lightburn and then re-install the software. Then if you make changes to any option setting you might want to do a screen-print of before and after so you know what you are changing.
I deleted and installed it again. Didn’t work the first time I did it but the second time it did, so I font know if that where the solution or just a lucky coincidence
