Need Help - Galvo Fiber Laser Not Framing or Engraving Properly (OMTech 50W, LightBurn)**
Hi everyone,
I’m hoping someone can help! I have an OMTech 50W Galvo Fiber Laser that I just connected to LightBurn. I’m struggling to get any successful framing or engraving going. Here’s what’s happening:
  • Laser fires only when actually starting a job (not during framing).
  • When I try to frame, nothing moves or frames properly at all.
  • Move panel is not active — I cannot manually move the laser head.
  • I’ve checked emergency stop, start/pause/mark delays, red dot offset, and galvo config, but something still seems off.
  • Settings: Galvo 2 = X axis (based on sticker on machine), Galvo 1 = Y axis.
  • Frame speed and settings are entered, but no movement happens when trying to frame.
I feel like I’m missing a setup step or a critical setting somewhere. Could someone walk me through what else I should check? Maybe my basic galvo settings, red dot offset settings, or delays need correcting?
I would greatly appreciate any advice — thank you so much in advance!
Ok, need some clarity
Laser fires only when actually starting…
There are 2 lasers, the red light framing laser and the 50W source laser, which one are you referring to?
Trying to frame, what are you expecting to move?
Move panel: laser head only mves up or down. With motor or crank handle, please elaborate.
Frame speed and settings..
Please elaborate.
Post screenshots of each screen that is up when you experience difficulties
Questions:
Did it ever work?
Did it work with EZCadd?
We’ll get you rocking or die trying!
Edit actually there may be a couple focusing lasers also…
