Need help to setting up my VigoEngraverL7 laser
From the screenshot you provide I see a ā€˜Open GRBL’ button. Do you know what version of GRBL this controller/laser system is using? That information will be critical for proper setup of LightBurn.
Have a look at this for a good place to help you get started.
I looked up the laser on Google - I can’t see anywhere on the listing what it’s running, so there’s a very good chance it’s proprietary. I did see ā€œNEJEā€ on the sample pictures, and if it’s one of theirs, it’s their own custom firmware, not supported by LightBurn.
I managed to let Lightburns to work with it however it’s not working As it should it’s giving me Homing Error number 5 And If I use the x and y it gives me different dimension that’s been set up by the manufacture And the power Off the laser is 20 W
ā€œError 5ā€ is GRBL telling you that you’ve asked it to home, but do not have homing enabled in the firmware. When you set up the device you probably enabled ā€˜Auto-home on startup’ which would tell the controller to home, and give you that error.
