I purchased an OemTech K40+ machine a year ago, and it came with a roller attachment and Lightburn included. Recently I decided to use the rotary, but I am having many issues with it to the point I am even thinking this attachment is defective.
The physical installation is done, but the Lightburn settings are confusing
To start, the mm per rotation is not clear. Lightburn says it is the circumference of the rollers. The diameter of the roller is 25 mm and the circumference is 78.54 mm. Why is Lightburn asking for it when it can be calculated with the diameter?
Also, once I entered the diameter of the object (60.7 mm) and hit “TEST”, the roller rotates the object almost one full rotation. Why not a full rotation if I entered what Lightburn asked for? After adjusting the mm per rotation (from 78.54 to 83), it does a complete rotation.
Here is what is even more confusing:
If the TEST is working fine, I would guess the settings are correct and I can go ahead and start engraving, or that is what I thought…wrong
If the object’s circumference is 190.695 (based on its diameter), I would understand I could be able to engrave a thin square with a length of 190.695 mm and cover the whole circumference of the object, however, when I frame the movement of the laser and the rotary, it covers twice the circumference of the object, meaning the square would completely overlap. What am I missing here?
I went and changed the mm per rotation to 41.5 so the framing shows one full rotation. Why does this value need to be adjusted if the roller diameter and the mm per rotation should never be adjusted? or that is what I thought.
Once more, by changing the mm per rotation messed up the TEST part in the rotary setup because it now rotates the object half. It needs 83.
Also, if this is a common issue setting up this attachment for every object with different diameter?
I decided to engrave a 40x40 graphic and the result is disastrous. The graphic is completely distorted and deformed.
I am using “Current Position” instead of “Absolute Position” and is it normal for the object practically rotates briskly before starting to engrave and once finished, rotates the object a few times really fast before stopping? Is there a way to tell Lightburn to start engraving right on the current location and stop and remain in the position where it finished engraving?
