When the laser railing transfers from one point to another the speed is too fast so when it reaches the ending point it skips a small amount of the coordinates and it messes up the end product since it cuts at a different point than it was ordered to, is there a way to change the transfer speed so it goes slower when changing cutting points?
That is most likely a mechanical problem, rather than a speed problem.
Scale this test pattern to fit the platform and run it as fast as it will go in Line mode with optimizations turned off and power set to mark a sheet of cardboard:
Any distortion of the pattern will give clues to what needs adjusting. Upload a picture of the results so we can look over your shoulder.
