Hi! I need your help! There is such a laser! IT RUNS UNDER THE acan PROGRAM under win. Is it possible to run it under the mac? Thanks!
https://aliexpress.ru/item/15000MW-diy-laser-engraving-machine-15W-laser-AS-5-steel-engrave-marking-machine-steel-carving-cnc/32749959155.html?spm=a2g0s.9042311.0.0.264d33ed7eaPw8&_ga=2.209036177.2022102594.1612607168-666461188.1612366913
I did not look at your link. The key for you to know, is the firmware and controller used to drive this laser. You will need to check if it is one of the supported firmware (Grbl, Smoothieware, Grbl-LPC, and Marlin) in LightBurn.
You may need to update the control board with supported firmware, if it is even possible.
