Seems after updating light burn i started getting an error 2 numeric value format is not valid or missing or missing an expected value, tried $RST=* pressed enter then reset then $I still not working
You have more than likely selected an incorrect device during it’s setup…
What device did you select? I thought these had a configuration file available for these machine…?
Ortur Laser Master 3 Ready! See below it runs for a while and stops and below is what it shows. I double checked the device it is connected to the right one
OLF:206.
OLH:OLM_ESP_PRO_V2.4B.
OLM:GENERAL.
GrblHAL 1.1f [‘$’ or ‘$HELP’
this is quite a old firmware, very old in fact
Latest is 210
you might need to do
206 - > 207
Then 207 - 210
Source files can be found here
210 DOWNLOAD LINK (23-02-2023)
207 RC0 DOWNLOAD LINK (21-10-2022)
Not sure what to do here Ive downloaded the links. I am a beginner.
Instructions
Download and unzip this file please
210 DOWNLOAD LINK
Extract zip file into desktop.
Inside it, you will see a ESP_OLM3_2010.bin file
Now with your machine connected via USB to your computer.
Tap the reset button once to turn off your ORTUR
Then do this sequence carefully:
PRESS and hold the reset button on the back of the motherboard. Do not release
Count 3 seconds
PRESS also and hold the power button. Do not release
Count to 3 seconds
Release Reset Button
Count 1 second
Release Power Button
Now your computer will show an ORTUR UPDATE drive – almost as if you had inserted a USB thumb drive
Copy the bin file we extracted earlier into the drive and allow the machine to do its update operation
It will take 30-60 seconds and the machine will home again
Reconnect to LightBurn or LaserGRBL – in the console type where it says (Type commands here) or (Type GCode here)
$RST=*
The machine will respond with
[MSG: restoring defaults]
At this point, you should be ready to use the device.
Note: your wifi settings if you had them will need to be done again
Thanks I’ll give it a go.
What program will open file for down load?
The downloaded files are zip files
Windows explorer allows you to unxzip them
From inside you need just to move the .bin files into the machine when in firmware mode
Sorry for being such a pain, I did get it downloaded and running it now. I’ll let you know. Thanks
This is what Im getting now
OLF:206.
OLM:GENERAL.
GrblHAL 1.1f [‘$’ or ‘$HELP’ for help]
$I
[ORIGIN:China]
[PRODUCER:ORTUR]
[AUTHOR:LEADIFFER]
[MODEL:Ortur Laser Master 3]
[OLF:206]
[OLH:OLM_ESP_PRO_V2.4B]
[OLM:GENERAL]
[DATE:20220920]
[SN:71F7433F76FF0808A3C59F94BB935AE0]
[VER:1.1f.20220325:]
[OPT:VNZHS+,63,32767,3,0]
Target buffer size found
[NEWOPT:ENUMS,RT+,HOME,NOPROBE,TC,SED,WIFI,FTP,TMC=7,SD,ITG,GT]
[FIRMWARE:grblHAL]
[NVS STORAGE:*FLASH]
[DRIVER:ESP32-S2]
[DRIVER VERSION:220327]
[DRIVER OPTIONS:v4.4.1-dirty]
[BOARD:Ortur Laser Master 3]
[WIFI MAC:58:CF:79:A7:0D:0C]
[IP:192.168.5.1]
[PLUGIN:Power Detecter v1.0]
[PLUGIN:Power Control v1.0]
[PLUGIN:gyroscope sensor v1.0]
[PLUGIN:Trinamic v0.09]
[PLUGIN:SDCARD v1.05]
[PLUGIN:ITG STREAM v1.00]
[PLUGIN:ESP32 WebUI v0.03]
[PLUGIN:GADGET v1.00]
ok
Project loaded in 137 milliseconds
Starting stream
Layer C00 Pass 1 of 2
It stops and the light goes blue on the machine. the busy timer is still running. it ran about a third of the way on the project.
you are still on 206, you need to be on 210
When you go through the update process, ORTUR drive apears correct, and you copied first 207 firmware file and let it update
THen done 210?
