Need help with setting up 2 lasers to 1 Lightburn
So I just got a new MacBook and my lasers are both running different controllers. One is Smoothie and the other is Trotec. I just renewed both licenses but can’t add the Trotec controller and the K40 in one Lightburn. The laser with the Trotec has its own computer running Trotec AWC controller and latest version of LB. MacBook Air only has smoothie driver for K40 which has Cohesion board. I have both licenses for smoothie and for Trotec version of Lightburn. Can I use them on the same computer? If so, how?
Hope I put this in the right place. I’m new here sorry.
Got it. How I fixed it was to download Lightburn again and under help> license management> deactivated license for smoothie and put it license for big laser and voila both lasers were there on device list.
There’s no limit to the number of lasers, that I know of… I have three led lasers and a Ruida…
If you make a ‘device’ for each laser, it will associate the proper library with the device…
If Lightburn will run both, you should be able to just add a device for the ‘other’ laser…
Thanks. I found that the license type was wrong for the laser I was trying to add. Yes. You are right and now I have library to match each laser.
