I had a NEJE 20 170mm x 170mm Laser and I purchased a NEJE 255 x 440mm 30 Watt Laser.
Will the laser work in lightburn if I just edit the size or preferably, can I have both and select either.
Can I run two lasers at the same time?
You will be able to run with both machines on separate sessions of LightBurn but the connection to the laser can only be established by one laser at a time. Of course there is no problem with 2 computers
You just create an extra laser profile with the new bed data.
