Neje 3 max with extensions - "home" error
I have bought a neje 3 max with extensions on, and really looking foward to start engraving :slight_smile: But cant seem to get lightburn to work with it. When i press home on the laser it goes to the corner as i shold do, but when i press show last position (the blue mark) its in the middle of the “workarea”
hope the picture can explain?
so if i try to move the laser 1cm from each edge it starts from the blue cross, not the cornor where its placed
Neje 3 - YouTube video explaning :slight_smile:
Hope you understand :slight_smile: can upload video if that helps or more screenshots?
Im not very good at writing english, but can fully understand it :slight_smile:
You might want to use absolute coordinates instead of ‘current position’ unless you get used to it before that way…
The ‘working area’ is set in two places, Lightburn “Edit → Device Settings” and within the controller as $130 through $131 and $132 for a Z axes.
Are both of these set properly?
Thanks :slight_smile: that worked =))
If it’s successful, mark it as ‘solved’… Glad you’re up and running again…
Take care
