i’ve a problem using lightburn with Neje 3 Plus. Squares and straight lines are ok but when it comes to circles the laser is doing crazy things. It’s not round but its angular. The same with text. In Lasergrbl it’s ok.
Attached a photo:
The round is from Lasergrbl and the crazy from lightburn
In the operation manual from neje.wiki it is described that neje 3 plus works with lightburn. Every manual step (movment control) in lightburn is a movement in the x and in the y axis. 1 in x are 3 in y.
Can you push “Save Gcode” in Laser window and save to a file with .txt extension? The upload file here. Will check to see if anything odd in the gcode.
This is indicative of a problem with license validation. I suggest emailing support@lightburnsoftware.com describing the problem and with a link to this Topic and they’ll help you sort out the issue.
