KimSlater
(Kim Slater)
August 28, 2023, 2:53pm
1
Hi
I have just switched to an Neje 3 from a 2 and I am having difficulty setting it up
I cant remember how I did it last time as I have a memory problem
Lightburn recognises the machine but when I home it it goes far left top and bangs into the bar
this is the message I get
Homing fail. Could not find limit switch within search distance. Defined as 1.5 * max_travel on search and 5 * pulloff on locate phase
Help would be appreciated thank you
richfaraone
(The Louisiana Hobby Guy)
August 28, 2023, 3:29pm
2
You probably have the settings wrong in the Device Settings. According to the Neje Wiki , the proper home position is front left. Sounds like yours is rear left.
KimSlater
(Kim Slater)
August 28, 2023, 3:33pm
3
Hi
I have followed the website instruction and put to front left and no better
If I try and frame a graphic it goes flying off to the right and stops at its limited and just keeps trying to go
latest error message
Stream completed in 0:08
ALARM:3
Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended.
KimSlater
(Kim Slater)
August 28, 2023, 3:35pm
4
ALARM:9
Homing fail. Could not find limit switch within search distance. Defined as 1.5 * max_travel on search and 5 * pulloff on locate phases.
ok
Grbl 1.1f [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
[MSG:Caution: Unlocked]
richfaraone
August 28, 2023, 4:03pm
5
Did you reset the home position, turn off the machine, and then turn it back on again so it could home properly?
KimSlater
(Kim Slater)
August 28, 2023, 4:21pm
6
Yes I did. I even rebooted the laptop
It’s almost as if it isn’t recognising the size of the machine.
I am lost at the moment
KimSlater
(Kim Slater)
August 28, 2023, 4:59pm
7
I have also found another issue - GRBL when I try to connect I get access denied comport 6 which is the post for the Neje
KimSlater
(Kim Slater)
August 29, 2023, 11:50am
8
Hello
can anyone help
I have reinstalled my laser on another computer and downloaded all required software and the same thing keeps happening
ALARM:9
ok
ok
I just cant find a solution
This is most likely going to be a hardware issue, not something in software.
There should be homing switches that are actuated at the top and left sides of the machine. Look for those. Manually move the machine while off to see if you can properly actuate those switches. You should feel and hear the actuation. If you cannot actuate the switches inspect the machine to identify what’s preventing that from occurring.
If the switches are getting actuated, check the cabling to make sure that everything is properly plugged in and recheck that all cables are in the right location.
KimSlater
(Kim Slater)
August 30, 2023, 1:48pm
10
That’s great advice thank you.
I have dismantled its holding area and there was a ribbon in the way of one of the switches.
Also had a little fiddle with origin and home.
All good now thank you.
system
(system)
Closed
September 29, 2023, 1:49pm
11
