Hi! I got my Neje laser hooked up and running but I can’t seem to find instructions on how to focus the lens. Lightburn has a helpful focus test tool but I’d like to optimize the hardware first. I found out you can screw or unscrew the lens to adjust focus, but there’s no details on which way to turn for what resultor how best to test it without running a full focus test (which requires unhooking the module from my CNC on every attempt). Anyone here with experience adjusting the lens?
I’m hoping to do both cutting and engraving, if that matters.
The lens is adjustable, says so in the poorly translated manual that came with it, and after some testing I’ve determined screwing it in brings the focal point closer to the lens. There’s no way to measure this other than testing as far as I can tell, but I’ve finally reached a more reasonable focal point, sitting about 20mm from the casing. I’m still not sure how it will impact the length of the “knife” for cutting operations tho, guess I’ll find out soon enough!
Extremely helpful thank you! Plus some new vocabulary for me to get acquainted with
I’m using lightburn’s focus test but my initial run had my Z axis come off its tracks while still burning instead of cutting, seems factory defaults have the focus set as far as it goes. If DoF is unaffected then I’m ready to move on to the next set of calibrations thanks!
