Neje and Lightburn cordinations don't match
Have: Neje Max 3 and latest release of Lightburn
I have problems with the coordinates in Lightburn not matching my Neje Max 3.
When I have a drawing in Lightburn that is within the “Working Area”, but close to the edge and I select “Start” I get an error message “out of bounds”
Looking for help to calibrate so that Lightburn and the laser match.
My wish is for “Home” to be in the upper left corner.
After doing a homing cycle, which position is reported in move window?
Home position
0, 460
Then you need to set the origin to the front-left (in your picture it’s the top-right picture where you need to set it, device settings). It homes to the back-left, but it’s configured to have its origin in the front-left corner, so you need to calculate from the front-left, as LB usually expects as well.
