Does anyone have a Neje Master 2 (non-homing) working? I have used the settings from the sight, and I assume it should be fine since I don’t expect different laser power to play a role if I can or cannot use the software.
However, my trial ( and extension ) is running out, and I don’t want to purchase it if it does not work for my laser cutter/engraver version. I also have no issue purchasing if I can get the benefits. I have searched the site and seen very confusing/mixed results.
Did you upgrade your Neje to GRBL 1.1f in Step 1. of the LightBurn setup link you provided?
Would you mind confirming the state of the Neje controller software by opening the Console window in LightBurn and typing the following:
$i
then press enter.
Please copy and paste that 2-3 line report into a reply here so we can confirm the first troubleshooting step.
Hello Rick, I have got it work. Move works, I can do a simple engrave, and now I am just figuring it out. I have 9 days left on already extended ( emailed support ) trial. I think I am good. I can play with this over the weekend. I am 90% I will purchase as I am starting to understand more about how to use the software. If there are any good training videos for a Lightburn beginner that would be appreciated. ( I have been using the NEJE laser for about 2 years) Thank you
If you think anyone would want my machine and device setting I am happy to post. If it will help someone else. It took some time and reach to find and figure out version 1 working values.
