wccrawford
(William Crawford)
November 17, 2020, 11:19pm
1
I just got a new Neje Master 2 Plus and I tried it out with the included software and it works.
I installed Lightburn and I’m attempting to set it up.
When I connect in Lightburn, I see this in Console:
Waiting for connection…
benbox laser 3.1© mul 2015.06.06
start
ok
ok
When I run grbl uploader 2.1 and hit connect, it identifies my machine as a NEJE MASTER 2 Plus, as it should, and then says:
This is GRBL Uploader, There is nothing to update for your device.
I feel fairly confident that the wrong firmware is installed, but I can’t figure out how to get the correct firmware.
I’ve seen several threads here and the northlakes site that gives instructions, but every time I get stopped at updating the firmware. It just doesn’t seem to be happening correctly.
Can anyone help?
Thanks!
wccrawford
(William Crawford)
November 18, 2020, 2:58am
2
I contacted Neje and they sent me a PDF with instructions and a new firmware file. If anyone else is having this issue, contact Neje and they’ll get things working.
Thanks and sorry for the (mostly?) useless post!
NEJE_Laser
(neje_laser)
November 26, 2020, 5:58pm
3
wccrawford:
start
ok
ok
Can anyone help?
Thanks!
NEJE has updated the firmware switching program, NEJE uploader 3.0, you can download and update to grbl1.1F firmware
NEJE_Laser
(neje_laser)
November 27, 2020, 3:04am
4
wccrawford:
start
ok
ok
Can anyone help?
Thanks!
You may need to use NEJE_uploader 3.0 to upgrade the firmware to version 3.0,wiki.nejetool.com
system
(system)
Closed
December 27, 2020, 3:04am
5
