So I’ve got an issue that I’m not sure how to fix.
I recently had my machine running the Ortur RYY.
I’ve disconnected that, and reconnected everything as it was to do some engraving, and my machine homes successfully, but when I try to even go frame something in the center of my machine work area, I get an Alarm 2 and my machine doesn’t move.
Any body have any ideas how to fix this?
THANKS!
Here is a read out of the error: Waiting for connection…
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
You probably haven’t set up your machine correctly. This is saying that your machine is being ordered outside of it’s working area. It’s occurring around line 2 or at the start, so it’s probably trying to move the wrong direction.
It is usually how you have it setup in the ‘edit ->device settings’ origin…
Thanks for that thought. I tried it moving the origin to every other point returning to bottom left which was what it was before, and it still doesn’t move.
It’s definitely a setting I’m missing, because I opened up the NEJE control software, and it moved and framed the image.
I tried removing the device and re-adding, and it still stays put after it homes and won’t move.
And I’m getting the same error still.
