i haven’t used the 2s for a while, and in the interim the software has moved on
my last available upgrade is 1.2.04, but prior actual work had been done on 1.2.01, which was working fine
i updated to 1.2.04 because trying to use a file created on that version on my desktop machine threw a message suggesting it may not work properly on the older version that is on the laptop that connects the neje in the workshop
the available working size is set at x=170mm, y=155mm, to accommodate a larger laser module (NEJE N40630 laser module) which worked well on these parameters without binding on limits
origin is defined as left front, as previously also
but when i try to have the module move to home, the mount hits the upper left limit
and the following appears in console-
ALARM:9 Homing fail. Could not find limit switch within search distance. Defined as 1.5 * max_travel on search and 5 * pulloff on locate phases.
how do i reset home?
i did it ages ago via console i think, but have long forgotten how, because until now it just worked perfectly
the constant grinding up against the limits on “return to home” is as grating as the sound it makes
If it goes to the right position but does not stop, that is likely a mechanical issue. Bad switch, switch moved, switch actuator moved, broken wire to the switch, or bad connection at the controller board. “Could not find limit switch…” is your clue.
so, if i physically press the switch with the laser away from home, should that result in the movement ceasing if i have pressed “home” on the software, as a simple check?
the switch makes a nice “click” when i press it, less so when the stop hits it if i try moving the gantry manually, but it has a nylon pin doing it, versus my finger
Yes, although in many cases it seems the “thing that should touch the switch while homing” has moved / bent / gotten misaligned just enough to not quite activate the switch.
Your finger is a good first check to see if the switch works, but (assuming it does) you must verify the laser head (or whatever) also pushes the switch.
