New to here and lasering in general so reaching out in order to get some information.
I am having trouble getting my Neje Master 2S Max cutting even things as simple as cardboard, even though i’ve had 2 successful engraves using cardboard.
Installed the Neje driver for lightburn from the Neje.wiki. Homing is fine, orientation is fine, but power seems to be my issue. I went through the common GRBL settings to see if I needed to change S-value Max, but I can’t seem to even be able to tell what GRBL version this board is using to confirm if its 1.1f. I have attached the below images of settings and setup for reference.
Please note that this line was done at 6000mm/min at 80% power
Any advice would be greatly appreciated, especially because getting some drawer organizers cut an assembled this weekend would definitely help me with the wifey.
