Check Edit->Machine Settings for value of $30. It’s likely 255 or 1000. Use the value from there and make sure S-value max in Edit->Device Settings is the same. If not, change S-value max to match. Note you can also check $30 from Console by typing $$.
Check Shape Properties window for the object you’re trying to burn. Make sure that Power Scale is set to 100%.
