I have a new neje max 4 with extension and i tried to extend axis in lightburn and now my laser is moving very fast and hitting the sides hard. I dont want to break anything. How can I fix this? Please help and thanks
Sounds like you changed the wrong setting, maybe? Show your machine and LightBurn settings.
It seems you changed the units from mm/min to mm/s. Check the main LB settings.
You are correct. I changed it back and nothing has changed. The laser is traveling very fast and aggressively, even when homing.
Did you change other GRBL settings?
You need to change your device to GRBL not GRBL-LPC.
Set your X travel to 750 and Y travel to 1030.
Try changing your X Max rate to 6000 and Y Max rate to 3000 then test.
That fixed the speeding! But it is still traveling to the edge and hitting normally and grinding. So helpful ty so much
Then there is this
Max requested distance 200.0000 and axtual distance 200.0000 gor x axis. Y axis is the same
Uploading: 20241114_185950.jpg…]()
Max4 is originally 750 x 460
What is the size of your extension?
You have to wait for the pics to upload.
Type $$ in Console and post here the output.
Change your origin to lower left.
