I have a NEJE Max 4 E80. I opened the NEJE Software and updated the laser’s firmware to the latest version. After the update, a problem appeared.
The laser’s working area is 750 × 1030 mm. After updating the firmware, the laser no longer recognizes the entire working area: physically, it only moves to about the middle of the working area, even though LightBurn still shows the working area as 750 × 1030 mm, and the same dimensions are specified in the settings.
Could you please tell me what might have changed after the firmware update and how I can fix it?
I really need help because I currently can’t work properly, and I have orders that need to be completed.
@ph_artem2303 the commenters above me here are correct - can you confirm you got your machine up and running by updating the firmware settings for your machine?
