NEJE brand new master 2s series motherboard’s hardware performance; 2s series motherboard will update the GRBL 1.1f of ATMEL chip to brand new GD32 MCU. Which has improved 50% performance compare with STM32 chip.
It supports more than 10 different function modules, the NEJE module has excellent optical design and reliable work performance, which is the best and the most guaranteed service currently. Each NEJE module has an intelligent control function, which is quieter to use, and has a heat management function to ensure that each module runs at a safe temperature and obtains a longer service life. NEJE series module provides 2 years free warranty.
Specialized Motherboard with GD32 MCU.
It could preprocess 32 instructions, support baud rate as high as 2,000,000, compared to STM32 desktop laser engravers, which only has 921,600, more powerful!
Engraving speed could be as high as 42,000 millimeters/Min. ( If do not consider the laser carving result, the velocity of movement could be as high as 1200millimeters/Sec. ); compared to stm32 desktop laser engravers, which only has 3000 millimeters/Min, more powerful!
The Most Advanced 32Bits Laser Engraver Firmware, smarter, faster, higher precision and easier to use. NEJE also provides firmware upgrade services
Laser power range could be S0 - S1000, NEJE Laser Master could control laser beam more accurately, could even use the high power laser unit to “draw” a picture on paper, to match with NEJE series module can achieve the more accurate effect.
Active Position Protection,There is a G-sensor on the motherboard, if the machine detects unauthorized movement, the laser beam will stop.
Exposure Duration Detection and Limitation,If laser engraver is under control, but users forget to operate and keep the laser beam working, extra safety will cut off in case the motor stopped moving, to prevent fire.
NEJE software ( free software ) supports windows 7, 8, 10. Mac OS. NEJE APP including android, iOS macOS, NEJE team develops it which is for beginner, it can provide high precision carving and CNC creation’s software, the operating procedures are automatic and simple, safe use. Especially the current engraving software, NEJE team keeps upgrade and optimization, also provides free upgrade services, you can get free upgrade services in wiki.nejetool.com
Benbox free software, supports Windows XP, 7, 8, 10.
Laser GRBL ( free software ) supports Windows XP, 7, 8, 10. Laser GRBL is the most popular carving software in the world, could import different format images, you could editing in PhotoShop, Inkscape, CAD, etc. and then connect to the engraver via laser Laser GRBL for engraving and cutting.
LightBurn ( paid software, lightburnsoftware.com ) supports Windows, Mac OS, and Linux. It’s the most popular paid carving software in the world, very easy to use.
NEJE module supports PWM control and temperature sensing, the module can adjust the focus by up and down, it also supports zoom module’s and focuses module’s installing.
Pre-assembled parts, it just has to install 6 screws, need 1 minute to install the machine.
810 x 460 mm large engraving area. The widest space is less than 600 millimeters, it just able to place a whole home-used table.
Aluminum profile frame + structured cabling, solid structure, smooth operation, attractive appearance, NEJE structure is different from other acrylic main structure, NEJE machine is using high-strength composite mostly. It also uses CNC art craft, to make sure pulley and aluminum material without any gap. Besides, it won’t deformation for a long time, which means it is robust and reliable.
