I have a question about the support of SVG file containing multiple nested <svg> tags.
I have a NodeJS program that assemble svgs from local files and placing them in correct order, then generate the merged file. But this process use nested <svg> tags for creating the layout.
My file read correctly in web browser and “look good” in Inkscape. The layout is the same as the web browser, but when I select the SVG, it show smaller dimension for the element than the current drawing. When I open the file in LightBurn, all of the elements goes to the origin top left of the file.
So, do this problem is linked to the usage of multiples nested <svg> elements in one file? Or it is something else?
Thanks for the help, I’m joining the file in question.
Nested files were definitely not supported as late as Nov 2020. I don’t recall seeing anything since then to revise that so that may indeed be the reason you’re seeing this.
So, I have another question : Is it possible to create the same layout, only using element supported by LightBurn ? For the positionning I’m using the height, width, x and y parameter of the nested <svg>, and getting these for placing the next nested <svg>, etc. I know that <g> can only get x and y thanks to the parameter transform="translate()" is there a way to give them width and height ?
Hi, I tryed this, the svg file i’m using in the nested layout are all using <g> with a transform="matrix()" that is generated by inkscape. I can’t use this value since is linked of each design and I have dozen differents design.
So does anyone know an utility program or a trick that can make a svg file compatible with LightBurn ? Something like an svg editor that save the layout but with a different xml structure ? Or is the nested svg support is planned in LightBurn ?
