hello,
You have previously said
LightBurnOzOwner / Lead Developer
This isn’t something I can easily fix - There are too many distro’s of linux, all with different versions of LibSSL in their kernels that aren’t compatible. I can’t recompile for half a dozen different versions of Linux.
We build on Ubuntu 16.04, and it’s tested on a few others. If I build against 18.04 I break everyone with older kernels, and vice versa, but it seems to be only the update check that fails, so it’s easily worked around.
My question is, What is the easy workaround? Because I have no idea.
