New 300 x 300 lens but working area is 120 x 120
Dear all,
I purchased a new lens for my galvo to be able to cover 300 x 300 area. I installed the lens and adjusted the height to 420mm because on the side I read F420. However, I am seeing an issue, my design is in the center of the workspace but the workspace is still showing 120 x 120 and the frame putting the design on the bottom left corner.
what should I do to fix these issues? I would hole that fixing the workarea , will fix the center of the design.
My settings show 300 x 300
I have the latest LB 1.6.0 and here is what my workarea looks like:
Thanks for your help.
GM
Could it be that the loaded .cor file shown in your device settings id for the original lens ? If so, I believe that will override every other basic setting, hence they are greyed out.
If you have a .cor file for the new lens load that, if not you will have to calibrate it via ‘laser tools’ dropdown then calibrate galvo lens.
