New computer...LB will not find my actual device
New computer…LB will not find my actual device. It is saying the device is 10mm x 10mm and Lightburn is only functional 2 of 20 attempts.
I have uninstalled and reinstalled LB several times. I have done the same with the CH30 driver
Do a Manual setup for the Device. It is dirt simple to do.
When i do Find my laer give me what i am assuming is a generic 10mm x 10mm laser then the options are next or cancel…no finish option…if i select next allows me to put in dementons. If i change the dimensions similar to my machine. LB give a screen of that size but the functions of a 10mm x 10mm job. Ie: I move the laser to the opposite side of the screen and the laser indicates it has only moved a few mm from the home position.
I have COMPLETELY uninstalled Lightburn and reinstalled. Uninstalled/reinstalled X7 and verified the CH30 driver is installed.
Is there anyway to run a diagnostic to verify the X7 control board has not gone bad. I have tested everything thing i can think of. Only 2 to 3 out of 20+ tests get the same results
Transfer all the LightBurn setup from the old computer:
This will eliminate a tremendous amount of hassle …
