New free tool for print & cut shops: SheetMaker
:printer::scissors: New free tool for print & cut shops: SheetMaker
If you print on a UV or flatbed printer and cut on a laser, you know the drill: lay out every piece by hand, line up the cut file, hope nothing’s off. I got tired of it, so I built SheetMaker.
You drop in your designs and say how many you need. It nests the pieces by their real shape to use as little material as possible. Then it writes a print file and a matching cut file for every sheet, with registration dots so the laser knows exactly where the pieces are.
:white_check_mark: Uses the smallest sheet that fits, and your scrap pieces first
:white_check_mark: Two-print ornaments (mirrored front + back on top) that line up
:white_check_mark: White ink dots for dark material
:white_check_mark: Works with my LaserVision camera software, and with LightBurn’s Camera Print & Cut (same 4 dots!)
It’s free on GitHub, with a full manual and sample files to try:
:backhand_index_pointing_right: GitHub - jkktech/SheetMaker · GitHub
Let me know what you think, and if you try it on your machine I’d love to see what you make! :raising_hands:
