So i bought a new laptop installed lightburn avtivated my galvo liscense and installed the drivers my old laptop runs the laser perfectly fine and normal but the new laptop cant find my laser so i entered it mannually after i got it connected the laser will frame and print but it prints super slow and makes popping noises it seems like
Also transfer the LightBurn settings from the old PC to the new one:
I did that was able to get it printing normal but now the text or image i want to print shows up as a line text and doesn’t change when i put it to fill or offset fill
My first problem was slow engraving but i had it at mm/min instead of mm/sec
On the actual burn, preview screen, or work area? If work area only has the problem, go to Window menu and select filled/smooth or filled/coarse.
Just at the work area fills the whole text tho
Thank you that fixed it
