I am usually pretty good at figuring things out, however, I am a bit stumped on this one.
I have a new 2024 MacBook Pro, M4 MAX, running Sequoia 15.5—
My old system was a mid 2010 MBPro (which connected perfectly over wifi)
I cannot get my system to see my laser. I can ping it successfully, but it will not show up in my devices list. It works fine on my wife’s laptop, also an MBPro (Late 2020). I have turned off my VPN, I have disabled my firewall, I have tried wifi and hardwire all to no avail. I have not tried USB because that’s not an option and there should be no reason for me not being able to connect via wifi as usual…
Thanks for the input, I will probably give it another go today… I will dig into my router today - hopefully I can figure this out. Its amazing that we are all having to become better at IT!
Still having an issue - can ping the laser, but lightburn will not talk to it. Unfortunately we are using a Spectrum router and they severely limit what you can do with them. I dont think its the issue thought because I can still use my other laptop without a problem. This is frustrating, I have a call into Boss to see if they know of a reason my system wont communicate.
Turn the laser off, then try pinging it again. If something responds, then the router has plunked another device at the laser’s IP address: that won’t ever work.
This troublehooting tip may be relevant:
Have you migrated the LightBurn settings from the “working” laptop to the new one?
Thanks Ed!
So when I received your suggestions my laser was already off - ping test PASS (no other device on the network with the same address)! Unfortunately I no longer had my problem child laptop in the shop so I had to wait until I got home to check the permission settings.
I think that is going to be the issue because sure enough, it was one of two programs that were disabled!
I will hold off trying to migrate from the working laptop unless changing the state of the permisson setting doesnt work.
