I did a simple 5 x 5 grid going from 1000 to 2000 speed and 60 to 100 power. 99% of my NWT burns are 1500 to 1750 and 90%. The 2000 @ 60% should’ve been almost white. The test on the right still seems to miss the mark since 5000 speed at 20% shouldn’t be very visible. Also, the test on the right should’ve had an almost black box for 2000 speed at 50 since my first test produced a solid black at 2000 speed at 60.It also used a line interval of .04 with is 635DPI, I had min set to 195DPI.
Are you sure the speeds are in mm/min, not mm/sec? The grid generator in 1.1.00 ONLY did mm/sec. The one released in 1.1.01 should now support mm/min as well.
I’ll check it again tomorrow. I have the 1.1.01 version.
