I have a G5 laptop with windows 10 and the new Adjust image is very laggy and hard to use with the slider if I click or slide one very small amount it jumps multiple amounts in either upper or lower adjustments, for example if I want to go from Contrast 6 to 7 it may jump to 10 with just a very small movement. Because of this small up and down arrow buttons added at the end of the slider would help and would be easier to adjust also add the ability to to just manually put in a value you want. I can do photo editing and other intensive use on this laptop without any lag issues so I do not know what the issue may be with lightburn.
