I don’t know the laser lingo well. I can’t get my laser to frame the workspace. i set the workspace according to what i measured entered those ib grbl and lb, but i kept hitting right side of my frame
$0=10
<Idle|WPos:0.000,0.000,0.000|FS:0,0|WCO:-1.000,-1.000,0.000>I also get this in consoul, i never saw this before and this after it hit the side again
[HLP:$$ $+ $# $S $L $G $I $N $x=val $Nx=line $J=line $SLP $C $X $H $F $E=err ~ ! ? ctrl-x]
I think your $130 should be 920 and $131 should be 900.
If you don’t have homing limit switches on this machine, make sure you manually place the head in the 0,0 position before you turn on the power and start lightburn.
If you don’t, the software thinks that it is in the 0,0 (home) position when it starts.
First of all, according to Sculpfun, your usable workspace area after installing the extension kit is 890x900 (I didn’t measure myself yet).
But there are some quite strange values in your grbl configuration. All your axis configuration seems to be quite off.
Here are my values:
