Newb question. I want to create different “cuts” for different text elements. Can’t seem to figure out how to do it or find anything in the manual about it. Everything just keeps adding to the same cut. How do I create a new cut? Thanks.
Select the color of a different layer at the bottom, prior to creating the object. Or, if the object exists, select it and then click a new color at the bottom to assign that object to a new layer. You can then change the cut settings for that layer.
Is this not working for you?
That did it, thank you!
