New Update Causing Much Longer Cut Times
After installing the most recent update last night, my project that takes 2 hours to complete is now taking 5.5 hours. Same project, same settings. just extremely slow. Is anyone else having this problem as well?
I am running this on a HP Pavillion and have not run into this problem until now.
Is this the actual cut times or the time reported in the preview window? Try loading a preferences file from before you updated. File Menu> Preferences> Load Prefs Backup.
it is actual cut time. I started this cut at 7:30a and it wont be done until 12p. I will absolutely give that a try once this project is done working.
that along with recreating the cut pattern in a new window instead of opening the file seemed to work. thanks for the advice.
