New update wont install 2nd time
V1.3.00 wont install gives me error unable to execute file in the temporary directory. setup aborted.
this happened 2 updates ago never was able to get it loaded tried all that was suggested last time.
Last update 1.2.04 loaded just fine no issues.
This has helped a few others with this problem.
Often just a system reboot will fix this as well.
Tried all no luck here
What OS are you running?
You’re saying you went through the remedies in the link that @micrololin provided and it did not work for you? That would be odd as those remedies are fairly brute force.
Can you confirm you’re able to create files in the temp folder manually?
Windows 11
